new guy Q
0 Members and 1 Guest are viewing this topic. Read 1500 times.
Berndt
new guy Q
« on: 2 May 2006, 02:41 am »
Hi, I have been lurking for a few years.
I have really enjoyed the AC.
I am building a set of Raw Acoustics Ra8s.
I intend to build a pc based hifi server.
I want to build a chime dac.
Is there a get aquainted fast to diy?
Shoot, I have been soldering on pcb for cnc machine tool controls.
Just need to know if there is a conjunctive step?
Berndt
new guy Q
« Reply #1 on: 2 May 2006, 02:51 am »
when they say if you are not a diy guru send it home, are there options?
Bring a poor brougham up to speed.
orpheus
new guy Q
« Reply #2 on: 2 May 2006, 03:27 am »
I don't know of a place that will get you up to speed on DIY, but there are books about basic electronics that can be helpful.  The Chime is made with a board, so it's much easier to build than a point to point project (meaning that the parts leads are soldered together directly and not to a circuit board).
I'm putting a Chime together right now.  I have built a few things, and things that I have learned in the past have definately helped in building the Chime.  A beginner could do it, but you would have to be very patient and very careful.  As long as you're comfortable soldering, can orient the parts correctly based on the picture on the circuit board, and take your time to carefully make sure that you've put the right part in the right spot, and that your solder joints are good, you could build a Chime.  You need to be able to solder, crimp, drill holes for the chassis (unless you buy it finished from Jim), and you need a few basic tools.  It could be challenging, but it's definately possible.
I do think that if this was my first project, I would be in a bit over my head.  Of course you would be able to ask questions here and get quick and very helpful responses if you find something confusing, which would definately make the task easier.
-Aaron.
robertwstephens
Excellent site for tools and advice.
« Reply #3 on: 2 May 2006, 01:38 pm »
http://tangentsoft.net/audio/new-diyer.html.  This site may not let you get there from an external link.  If not, go to Google and type in "getting started in diy audio".  Excellent information.  Helped me immensely.  Kit build is a ton of fun!  Plan to go over budget on equipment and upgraded parts.  Peace.  Robert
Berndt
new guy Q
« Reply #4 on: 2 May 2006, 05:32 pm »
Thanks for the replies, that is exactly what i was looking for.
Being a machinist for the last 25years has given me handle on the metalwork, just need to hone my soldering skills now.
I work for a municipality now so I have a lot of time on my hands that diy is going to fill.
