Anybody tried the B&W 300 series?
0 Members and 1 Guest are viewing this topic. Read 1215 times.
RH Customs
« on: 2 May 2006, 01:50 am »
Has anybody tried the B&W 300 series?
RH
Digi-G
« Reply #1 on: 9 May 2006, 06:21 pm »
I haven't heard them, but I've read some good reviews of them.  Specifically the 303's.  They don't do a lot of bass - they bottom out around 72Hz - that's not much bass - a subwoofer would be recommended.  Apparently they won't go super loud either.  So I guess it depends on your listening habits and the equipment you currently have.
If you're looking for an all-purpose speaker (i.e. no subwoofer) I'd probably keep looking.  If you could step up to the 600 series (more money, of course) I think you'd gain quite a bit of performance.
Edit: here's a link to B&W site to do some comparisons (no prices, though)
http://www.bwspeakers.com/index.cfm/fuseaction/products.ranges
Good luck.
electricbear
re b&w 303
« Reply #2 on: 9 May 2006, 07:26 pm »
I would do the B&W 600s over the 303s. The 600s are far more refined sounding as they use a kevlar mid as opposed to the fibreglass in the 303. They have a little less bass than the 303 but are definately a better speaker at the same price.
