Question about resistors
0 Members and 1 Guest are viewing this topic. Read 1485 times.
gurevise
« on: 29 Apr 2006, 02:08 am »
Hi,
I have a general question about resistors.
Digikey carries following resistor types:
1. Carbon Composition
2. Carbon Film
3. Metal Film
4. Metal Oxide Film
Which of these type are preferable for audio use and why?
I understand/think that carbon types are less temperature stable and more noisy due to the size of carbon molecules. But some people swear by carbon resistors for some applications. I don't know why. I would think, metal types are better resistors overall but again which of metal type resistors?
Sergey
Dayton, OH
jon_010101
Re: Question about resistors
« Reply #1 on: 29 Apr 2006, 03:00 am »
Quote from: gurevise
2. Carbon Film
3. Metal Film
4. Metal Oxide Film
This is a rather tough question.  All have advantages and disadvantages, and will be suitable for different tasks.  You might want to check out some online resources, for example http://www.sasaudiolabs.com/theory10.htm.
Carbon composition resistors, for example, are not very stable, are noisy, exhibit voltage-dependent-resistance, yet are entirely non-inductive and can survive huge pulses (but can catch fire); they tend to sound very good and are great for vintage tube gear.  Carbon films offer lower noise, and greater stability, however they exhibit greater inductance; they too can sound quite good (Riken / Kiwame, for example).  Frankly I can't say much about metal types... they are less-noisy and more-stable than carbon ... But I don't use them in my vintage gear because they always brighten the sound up too much!  I think these vary greatly by construction, so some research should be done before picking a metal resistor.  For example, avoiding magnetic materials (steel leads, for example) in resistors is crucial for a good sound ... although I really don't understand why :|
Now, the really good stuff... tantalum resistors and bulk foil.  Supposedly the best for audio, but prohibitively expensive.  Since I won't spend $5-25 per resistor, I have never even bothered to try them.   :mrgreen:
Anyways, you'll also find that different resistors will sound good in different parts of a circuit.  My advice would be to try standard carbon/metal film resistors (audio grade, non-inductive leads) first and then upgrade a few at a time that do important things (for example, those that provide loads, feedback, or carry a decent chunk of current) and see what floats your boat.   :wink:
SHIF
« Reply #2 on: 29 Apr 2006, 10:40 pm »
Angela Instruments sells parts to DIY amp builders (guitar and audio) and have a nice commentary on the sonic merits of various resistor types.
http://www.angela.com
Click on "resistors" from their side  menu, scroll to the bottom of that page.
I bought Rikens from Angela for my Cornet.  No need for extras since every single one measured exact value.
