0 Members and 1 Guest are viewing this topic. Read 3888 times.
buy a refoam kit off ebay or contact big b and buy a whole pr from him
give it a day and one of the oldtime dealers will have the answer-or pmribbonspeakers-great guy
We did that glueing on the base trick only in 1984 and 85. The glue should be brittle by now and a few taps with the hammer and 2x4 makes it loosen up.Reattach the base with woodscrews once the PR is replaced.20 years is pretty good service. The replacement PR is $42.
You can also use some silicone to make sure there's no air leak.
You can just bolt it to the cabinet. Be sure to cut out a hole that will let the gasket seal nicely. Better to cut a little too small at first if you are not handy at this like me. Then obviously if need be you can open it up a bit more if need be.Brian has the greatest idea when screwing something to mdf. Use drywall screws. These hold tight even with all the vibration even over a long period of time. I know as I've checked mine over the years and they stay tight. You don't need to drill a pilot ...
