0 Members and 1 Guest are viewing this topic. Read 4567 times.
Problem solved without having to touch the speakers. The capacitors were dead. I'll just replace them and be up and running. Do you dare me to replace the caps with Jupiter Caps or maybe Duelunds? Just kidding, I'll settle for copper foil Jensens. Scott, I won't need the speakers, but I'll still bring you my Miles/Gil Evans set to borrow as long as you like.
Okay. Now the right channel 5" driver doesn't work right? The sound is distorted and thin. Blown driver/drivers? Any suggestions on how to trouble shoot? The RCA connections are all good and the cable is good. The speaker connections are good. The replacement caps are good. The cap connections are good. Thanks for your help.(Scotty, may I take you up on those drivers afterall?)
