Any one using tubes with their PSB Goldi's?
0 Members and 1 Guest are viewing this topic. Read 1016 times.
Huck
« on: 28 Apr 2006, 12:20 pm »
Hi: I will try another approach for comments...... anyone using tubes with their PSB Goldi's? If so, what are you using and how much power? I listen loud to rock, so don't know if tubes are the way to go here! Thanks, Keith :?:
John Ashman
    • http://forum.adnm.com
« Reply #1 on: 28 Apr 2006, 02:13 pm »
Maybe, but Golds are too hard for most tube amps to drive and I think they would respond better to a beefy 200W power amp, though I'd never tried it.  Besides, I think theyre forgiving enough on their own without the need for tubes in the mix.  What don't you like about the Goldis?
Huck
« Reply #2 on: 28 Apr 2006, 03:17 pm »
Thanks John: I love the Goldi's, but right now they seem to be a little bright for my liking. Mostly the room, I guess,but don't want to "go there" right now. I am using a Yammie a/v/ receiver, but treble is cut right back and annoying when turned up. I like the "sound " of tubes, but the Goldi's are pretty power hungry, so tubes, I think will not work. Keith
  • Speakers....What Speakers ?
« Reply #3 on: 29 Apr 2006, 05:31 am »
You might checkout a few hybrid amps...Butler, Blue Circle, ect. You'll have the power of SS with a tube-like sound....works for me. 8)
Huck
« Reply #4 on: 29 Apr 2006, 01:47 pm »
Thanks Lonewolf: Too many ways to go!! Will look into the Hybrids. Thanks, Huck :wink:
