Stick on Speaker Spikes
0 Members and 1 Guest are viewing this topic. Read 5476 times.
Rocket
« on: 28 Apr 2006, 02:46 am »
Hi,
I'm about to finish my diy speaker kit and i am wondering if anyone has experience using this type of speaker spike?
I would like to use this type of spike as i don't want to drill into the speaker cabinet.
Regards
Rod
Martyn
« Reply #1 on: 28 Apr 2006, 03:03 am »
My cone spikes have a flat base. They're intended to screw onto a stud in the base of the cabinet or onto a machine screw fitted from inside the cabinet. I didn't want to do either so I just used some double-sided adhesive tape to hold them in place. It's worked well so far...
DSK
Re: Stick on Speaker Spikes
« Reply #2 on: 28 Apr 2006, 04:24 am »
Quote from: Rocket
Hi Rod, some use spikes to couple the speaker to the stand, others prefer to couple the stand to the floor with spikes, but to use some inert material (eg. Blu-Tac) to provide a good grip to the stand with a little isolation.
If your speaker boxes are reasonably rigid and well damped (ie. they don't need to 'drain' box resonance out to the floor via the stands - I'm not sure that really works that well anyway) then I feel that you are better off using something that is rigid enough to prevent any speaker box motion, but 'grippy' enough to prevent a small knock sliding the speaker off the stand (as spikes would do unless their points fit into small holes or fixed spike dishes on the stand's top plate).
I would consider either Blu-Tac, rubber washers, or shallow rubber feet ... used at 3 points, not 4. You would not need to screw or glue the washers or feet to the speaker or stand, they should be grippy enough to be placed on the stand, then the speaker on top.
Just the other day I read somewhere that a speaker designer (was it Dave Ellis or Dennis Murphy?) tested various speakers on various stands and found that the more rigid and self-damped the speaker boxes were, the less audible any differences between stands were.
For a dollar or two you can try the Blu-Tac, rubber washers (or cork I guess) or rubber feet without damaging the speaker or stand, and change later if you don't like the effect. If you select rubber feet, go for something shallow (eg. 6-10mm) with say a 16-20mm diameter, rather than the taller ones that may have some flex in them under load.
Rocket
« Reply #3 on: 28 Apr 2006, 09:04 am »
Hi Guys,
Thanks for the replies.  My diy speakers are floorstanders and i won't need to use stands.
I am concerned that the sticky backing will continually fall off the base when i move the speakers around.
I know it is a silly post but i'm hoping for your opinions.
Regards
Rod
DSK
« Reply #4 on: 28 Apr 2006, 01:42 pm »
Ah, for some reason I thought you were building the 1's ...must be the 2's.
What type of floor do you have ... concrete slab or suspended? What is the surface ...boards, tiles, carpet?
mca
« Reply #5 on: 28 Apr 2006, 03:45 pm »
Find out what cones Klaus uses on his Lorelei speakers. When you stick those suckers on the bottom of the speaker, they do not come off. I had to use a putty knife to get them off!
hanguy
« Reply #6 on: 28 Apr 2006, 07:38 pm »
I have use the Soundcare self adhesive SuperSpikes on my DVD player with good effect. I think they can support speakers according to their 400Kg/spike spec. Take a look.
http://www.superspikes.com/
Tweaker
« Reply #7 on: 28 Apr 2006, 08:11 pm »
I use Mapleshade Conepoints with no screws or adhesive. Need to move the speakers just tilt the speaker,slip  them out from underneath and replace when the speaker is positioned where you want. Audiopoints also sells spikes/cones without screws or adhesive:
http://www.audiopoints.com/audiopoints.html
