SP1.7 - How to put the LCD display light off / Sensitivity ?
0 Members and 1 Guest are viewing this topic. Read 3387 times.
flom
Hi all, I am an sp1.7 new happy owner!
I already have two questions please  :mrgreen:
First, I would like to put off lcd display. The OSD function is not clear to me. It does not do that.
Is there any hidden code allowing to disable the lcd panel light?
I previously owned a Proceed AVP preamp. This preamp allowed to manage an level of sensitivity for analog inputs. I don't manage to find this function on sp1.7 and the result is a very important difference of volume between the Bypass sources and the digital ones and masterised (DLPII...). Do you have any idea please?
Thx in advance for your help
fabien
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1 on: 28 Apr 2006, 01:54 pm »
Hi Fabien,
There is no code to reduce the level of the LCD display on the SP1.7. The new SP2 has a feature where the LCD goes to 1/2 brightness.
The reason the Digital Volume is different from the Bypass is that the Bypass uses a stereo analog volume control and not the DAC's.
james
flom
« Reply #2 on: 28 Apr 2006, 02:00 pm »
Quote from: James Tanner
Hi Fabien,
james
James, I was lent (before the final acquisition) another sp1.7. This one automatically swtiched off the lcd display after a time without activity (5 second?). This one provides also a quite similar level of input between Bypass & other inputs ?
Am I clear ?
Cheers
Fabien
« Reply #3 on: 28 Apr 2006, 02:05 pm »
Hi fabien,
The latest versions of the SP1.7 - new lcd displays allowed you to adjust intensity. Code - 240 then use the volume control to adjust brightness.
You may have an earlier version of the SP1.7 than the previous unit you had.
james
flom
« Reply #4 on: 28 Apr 2006, 02:19 pm »
Hi fabien,
james
James, thx for your very very fast answers.
The characteristics are:
SW/FW : 44A
Date : 0406
S/N : 000750
You do confirm that nothing is possible?
Phil A
« Reply #5 on: 28 Apr 2006, 02:20 pm »
James, I know you noted that a new display won't be included in the SP 1.7 upgrade.  Is that something that would be very difficult or non-cost effective to do for an additional cost.  Thanks
« Reply #6 on: 28 Apr 2006, 02:28 pm »
Quote from: flom
Hi fabien,
james
SW/FW : 44A
Date : 0406
S/N : 000750
I will check for you. Try the code and see if anything happens on the display.
james
james
flom
« Reply #7 on: 28 Apr 2006, 02:37 pm »
I will check for you. Try the code and see if anytnig happens on the display
James, I tried the code, & when I use the "mute key", the préamp mutes & the vol keys continue to manage the volume. It does not seem to work.
Thx in advance for your input
Fabien
Levi
« Reply #8 on: 28 Apr 2006, 03:32 pm »
I have an older version of SP1.7.
Fellow SP1.7 suggested this product.  I have not tried it but some claimed it works really well.
:lol:
« Reply #9 on: 28 Apr 2006, 03:33 pm »
Quote from: flom
Fabien
Are you hitting the 'CODE' button first until the red LED lights.
james
« Reply #10 on: 28 Apr 2006, 04:53 pm »
Hi Fabien,
I checked with engineering and their answer below.
It has the old display and PSB software 603 so  no intensity control available
james
flom
« Reply #11 on: 28 Apr 2006, 05:48 pm »
Yes James, I hit the Code key then (the remote led is lighting), then the 2 other keys (DTS/SRD), and MUTE. This key mutes the system...I interpret that the 2 first keys a re not understoof by my system?
« Reply #12 on: 28 Apr 2006, 06:04 pm »
Hi Flom,
Yes please see above post - your unit has the older LCD display so there is no control.
james
flom
« Reply #13 on: 28 Apr 2006, 06:21 pm »
Too bad  :evil:
Nevertheles, will it be soluble w/ an SP2 upgrade?
Fabien
