Best resistors?
0 Members and 1 Guest are viewing this topic. Read 941 times.
James Romeyn
Best resistors?
« on: 27 Apr 2006, 05:17 am »
Are the $10ea Vishay's still considered the proverbial "cat's meow"?  Anything else considered equal or better?  Thank goodness I only need a couple.  I got them from Percy earlier.  Anyone else stocking them now?  Thanks.
StevenACNJ
Best resistors?
« Reply #1 on: 27 Apr 2006, 09:43 am »
Depends on the project:
1. You can get Mills resistors from Sonic Craft. They have a wide variety. Parts Express also has them but more limited in selection.
2. Parts Connexion has a wide variety of resistors - Rikens are very nice.
James Romeyn
Best resistors?
« Reply #2 on: 27 Apr 2006, 03:48 pm »
I'm looking only for resistors that users have compared to the $11ea (maybe more now, that was '95) Vishay's.  Whatever testers consider equal or better overall, not a step down.
A friend & I were surprised how close the $.40ea Dale's got to the Vishay's, but they were still a step down.
SET Man
Best resistors?
« Reply #3 on: 27 Apr 2006, 11:01 pm »
Jim,
   Don't forget the Caddock line.  :D I personally have not compare them to Vishay. But I know that they are better than the Dale, Halco and Roderstien.
   I have some in my Audio Note M1 Phono pre and Welborne Lab Apollo 1.5 SET amp. I use mostly the MK-132 in the signal path. And I do have the TF020 lower watt (.33) in step ladder volume control (all with Holco) as a pre-attenuation and it is very tranparent... more so than the MK-132. :o
   They run from $4 to $11. So, I think they are a good alternative to the Vishay. Are they the same or better than Vishay? I don't know. I wish I have time to compare them.  :D
Take care,
Buddy :thumb:
