Poll
Which universal player to modify?
Samsung DVD-HD941 $105
2 (15.4%)
Toshiba SD-6980 $150
0 (0%)
Pioneer DV-79AVi $720
0 (0%)
Yamaha DVD-S2500 $500
0 (0%)
Denon DVD-2910 $510
2 (15.4%)
Denon DVD-3910 $890
8 (61.5%)
Denon DVD-1920 $280
1 (7.7%)
Total Members Voted: 13
Voting closed: 26 Apr 2006, 02:44 pm
0 Members and 1 Guest are viewing this topic. Read 1575 times.
rmihai0
« on: 26 Apr 2006, 02:44 pm »
Hi all,
I am looking to get a new universal dvd-player (with SACD, DVD-A and HDMI) and modify it for better sound/picture.
As always, the money are a problem.
That is why my researches indicated, so far, that the top candidates should be IN ORDER:
1. Samsung DVD-HD941 $105
2. Toshiba SD-6980 $150
3. Pioneer DV-79AVi $720
4. Yamaha DVD-S2500 $500
5. Denon DVD-2910 $510
6. Denon DVD-3910 $890
7. Denon DVD-1920 $280
The buget for parts is limited to US$250 / 200 EUR.
From your experience and in your opinion, which will offer the BEST BANG FOR THE BUCK after modifications? (not the best sound overall, but rather the best quality/price ratio).
Thank you
welwynnick
« Reply #1 on: 17 May 2006, 05:50 pm »
Strongly recommend the Pioneer DV-59AVi for lots of good reasons.
Dan Driscoll
« Reply #2 on: 18 May 2006, 03:39 pm »
Given the $250 upgrade limitation you imposed, there's no question you would get the most bang for the buck by getting the Samsung and upgrading it. But that's a cop-out, because several players on your list would still be better than a Samsung with $250 worth of modifications. Those would include the Pio DV-79Ai,  the Denon DVD-3910, the Yammie DVD-2500 and maybe the Denon DVD-2910. A few others would be the Pio DV-59Ai that welwynnick mentioned and the Sherwood Newcastle SD-871.
Buying a cheap player and throwing a couple hundred dollars worth of modifications at it should improve the performance. But it is probably not going to be as good as a better quality, un-modded player, although you might get close if you plan your mods judiciously, do the work yourself and know what you are doing.
Levi
Re: Which universal player to modify?
« Reply #3 on: 18 May 2006, 10:33 pm »
Are you going to be doing the modification?
$250 for parts is great if you are doing your own modification.   I agree, the Samsung would be the best to upgrade.
Good luck and have fun.
Quote from: rmihai0
Hi all,
From your experie ...
