0 Members and 1 Guest are viewing this topic. Read 4722 times.
You said something about "balanced" in there...not sure of the context.If you are talking about a system with balanced interconnects as opposed to unbalanced...power conditioning is moot.Systems with balanced interconnects throughout do not have issues with ground-path noise or oscillations, so there is no need whatsoever for a power conditioner, unless you are one of the 1 person in 1000 that lives next door to a large manufacturing plant or other egregious noise source.If you are using unbalanced in ...
Just a quick note - Gary and I spent last Sunday at Chez Occam. We learned a number of significant things. The P-8 benefitted substatially (nay, demands) a Felicia or similar powerconditioner. It cleared away substantial 'mud'. Please note that evaluations of components was done with just the DUT (device under test) either into a conditioner or plugged directly into the dedicated outlet. All other components were powerconditioned.Same goes for Gary's Nuforce amps, though the changes wrought by conditioning were not as great as with the preamp. It should also be noted that Gary felt the changes at his own exurban home were not as major. ...
...My pet theory is that the amps are getting noise back into the power grid and adversely affecting other components....
