Any Thoughts on the Vincent Audio SP-996 Power Amps
0 Members and 1 Guest are viewing this topic. Read 975 times.
Antman27
« on: 24 Apr 2006, 05:41 pm »
Any Thoughts on the  Vincent Audio SP-996  Power Amps?
I Now have a denon 3805 driving my Paradigm Studio 40's V.3
And I am looking for more power to drive the lows .
My main complaint on my 40's is at low listning levels there is not enough eungh = Lows .
Thanks ~
I also am out of space for a conventional amp
_scotty_
« Reply #1 on: 25 Apr 2006, 12:16 am »
The Denon website shows your receiver having tone controls and the Paradigm website has your speakers starting to roll-off the bass as early as 62Hz.  I would suggest you use your tone controls to boost the bass a little
when you are listening a lower volumes.  A bigger, badder power amp won't help you that much and it will put a hole in your wallet.
Scotty
opnly bafld
« Reply #2 on: 25 Apr 2006, 12:23 am »
Do you have a sub? The nice thing about a sub with a HT rec is that you can easily run the volume up at lower levels and turn it off if not needed at higher levels.
Lin
Antman27
« Reply #3 on: 25 Apr 2006, 02:38 pm »
I do have a Paradigm PDR8 sub.
I have played with a bunch of setting like changing the speaker settings from Large to small & play with the crossover setting from 80 to 200
