Outlaw Amps
0 Members and 1 Guest are viewing this topic. Read 1359 times.
guest1632
  • Guest
Outlaw Amps
« on: 23 Apr 2006, 03:34 pm »
Hi All, has anyone tried these M200 Mono blocks from Outlaw Audio? Just curious how they sound? Was thinking about getting a pair.
Ray
darwin
Outlaw Amps
« Reply #1 on: 23 Apr 2006, 04:57 pm »
I used them for about a year and a half to drive Maggie 1.6QRs and CC3s. I thought the amps sounded surprisingly good considering the amount of money I paid for them. They were recently replaced with Exodus UcD400AD amps which to my ear are better sounding - more detail and punch, and cleaner.
jhenderson010759
    • http://www.innovative-dsp.com
Excellent
« Reply #2 on: 23 Apr 2006, 07:44 pm »
I used them to tri-amp my Orions.  I still haven't decided if I like the Hypex UcD180-based amps I built better than the M200's.
Now, they are used to tri-amp the MTMs in my den.  Great amps, very reliable and flexible.
guest1632
  • Guest
Outlaw Amps
« Reply #3 on: 23 Apr 2006, 10:42 pm »
Quote from: darwin
Hi Darwin,
Did you build your UCD amps as a kit, or buy them already made from Kevin?
Ray
darwin
Outlaw Amps
« Reply #4 on: 23 Apr 2006, 10:58 pm »
Quote from: Ray Bronk
Hi Darwin,
Ray
Kevin built them.  I had him build a two and a three channel for me. The build quality is excellent. I may build the next one myself using one of Kevin's upcoming kits (a four channel to drive my IB subwoofer) to save myself a few pennies and gain some experience with DIY.
ajzepp
Outlaw Amps
« Reply #5 on: 24 Apr 2006, 07:42 am »
I've owned M200s for about three years now. They are GREAT for HT, but even though they are very reasonably priced, I just can't recommend them for music anymore. If the primary focus of your home audio system is HT, though, then you'll have a hard time finding anything better.
I used them for Paradigm studio/100s, Magnepan MMGs, and briefly on some Von Schweikert VR-1s. They always did a great job for me.
I just replaced them with a Butler 5150, and, as expected, the difference is reall something. But the Outlaws are great HT amps, and will do an adequate job with music.
