portable cd player and Monica / other DACs
0 Members and 1 Guest are viewing this topic. Read 1651 times.
m1brown
« on: 21 Apr 2006, 02:46 pm »
Hello -
Has anyone used a Monica (or other DAC) with a Discman-type portable cd player? A friend suggested I try this with a shock proof player - supposed have very little jitter and I bought a Phillips player with a line out but haven't been able to get it to work - I don't know if it needs to specifically be a digital out form the cd player, or even if they make such a thing...
Thank you,
Mike
San Francisco
Vinnie R.
    • http://www.vinnierossi.com
Re: portable cd player and Monica / other DACs
« Reply #1 on: 21 Apr 2006, 07:04 pm »
Quote from: m1brown
Hello -
Thank you,
Mike
San Francisco
Hi Mike,
Welcome to AudioCircle!
I remember going to a Head-Fi meet in Boston and one of the members had a Discman with an optical digital output.  I brought an optical-to-coax digital converter (also running on an SLA battery) and fed this into the Monica dac.  It worked very well.
There are also "iPod-like" players out there that have a digital output.  If you go to headfi.com and search in the "portable audio" section, you'll probably find a few.
Best regards,
