Van Alstine 550 EXR compared to Blue Circle BC 24
0 Members and 1 Guest are viewing this topic. Read 1113 times.
warnerwh
« on: 21 Apr 2006, 04:38 am »
cancelled.
  • Speakers....What Speakers ?
« Reply #1 on: 21 Apr 2006, 05:00 am »
Power wise...they are different..... 80 watts compared to 250 watts.
    Would matter depending on one's speaker choice. :) [/list:u]
warnerwh
« Reply #2 on: 21 Apr 2006, 06:12 am »
I should mention that both of these amps are only driving the planar/ribbon part of the Vmps speakers. Even the BC has enough power for that. The AVA is obviously way overkill but try to find a late model one used, your choices are limited to say the least.  The power of these amps will have nothing to do with the sound.
