Super Tower power requirements...
0 Members and 1 Guest are viewing this topic. Read 1905 times.
Davidinvic
« on: 21 Apr 2006, 02:38 am »
I purchased from Brian a set of Super Towers with focal tweeters, mid-range ribbon , 10" mid bass, 15" woofer and 15" passive radiator (sp?) approximately three years ago.  I lived in San Diego at the time.  I've now relocated to Victoria, BC and am having a real tough time finding a "budget" amplifier to run them as my old Carver (300w per side) equipment fades.  I believe I have just toasted a new NAD 372 with its 150wpc output.  According to Brian, the impedence of these marvelous speakers can be as low as 3.6 ohms.  Any brand/model suggestions? Trying to keep costs reasonable as we just had twins...and audio needs must for a bit take a back seat in the list of priorities.  Thank you.
john1970
Try a used Adcom amp
« Reply #1 on: 21 Apr 2006, 03:32 am »
You might want to try a used Adcom amp and use the NAD as a preamp if at all possible.  I am amazed that you damaged a NAD C372.  I am currently using that exact amp to drive a pair of RM40s in a 14' x 25' x 8' (W x L x H) living room.  At a 9' listening distance I can drive the speaker easily to 95 dB peaks without any problems for an entire CD (Metallica S&M Disc 1).  Once I had a problem when I left the doors of my hifi cabinet closed during listening to a movie and the amp did go into thermal protect mode.  However, after the amp cooled down everything went back to normal.
Some questions to consider:
1) How is the airflow around the amp?
2) How large is your listening room?
3) How loud do you listen to music?
IMO you will need a larger amp if you do farfield listening in a large room.  Lastly, a larger amp will give slightly better bass and I do mean slightly (based on my comparison between my NAD C372 and a Bryston 4BSST driving a pair of RM30Ms).
Good luck,
John
Davidinvic
Nad 372
« Reply #2 on: 21 Apr 2006, 04:36 am »
Thanks for the thoughts, John.  The Nad is in a cabinet with no doors and 6" airspace above.  It goes into thermal protection mode after about 1.5 hours regardless of the volume of the music.  I will reconnect with it totally exposed on all sides and see what happens.  I like the amp...and a fair value for the money.  And it even has tone controls which are currently out of favor.    I am concerned that with moderate listening levels it may have a very short lifespan as it does seem to generate a substantial amount of heat and the manual has all sorts of warnings about not running spaeakers below 4 ohms.
john1970
A few additional points
« Reply #3 on: 21 Apr 2006, 09:50 am »
A few additional points:
1) I've used the amp for listening to music for ~2 hours straight with no problems at moderate listening levels (80-90 dB 9' from the speaker).  I admit it does get warm, but does not go into thermal protect mode.   If in a cabinet try to install a small cooling fan.
2) Remeber that when an amplifier specifies a minimum 4 ohm load that the spec is refering to a nominal (average) impedence.  Many 4 ohm speakers have dips that are well below 3.6 ohms.  I am still having difficulty believing that the NAD is going into thermal protect mode.  NAD does specify a dynamic power into a 2 ohm load which suggests that it can handle temporary dips into the 2 ohm region.
3) You might want to ask NAD directly at their website.  Although I've found that getting a reply takes a long time and the response is not always very useful.
http://www.nadelectronics.com/help/
4) In the worst-case-scenario use the NAD C372 as the preamp and a used Adcom GFA-555 MkII (used ~$500) as the main power amp.
Please let me know how it turn out,
John
flintstone
Supertowers
« Reply #4 on: 21 Apr 2006, 01:20 pm »
I've been driving mine with an Onkyo M-504 for 9 years...never a problem even at very high SPL's. Mine are part of an old VMPS surround sound system I bought new...still sounds great even after 9 years!
Dave
john1970
Increase Air space above amp as much as possible
« Reply #5 on: 22 Apr 2006, 01:59 pm »
Last night I increased the air space above the NAD C372 to ~ 7.5" from 4.5 inches I noticed that it does run substaintially cooler.  I am looking for a quiet cooling method to cool the amp even further.
PLMONROE
« Reply #6 on: 22 Apr 2006, 03:49 pm »
You might try a super quiet computer fan above it. Even the slightest increase of air flow will do wonders.
Paul
Davidinvic
Thanks to all...
« Reply #7 on: 22 Apr 2006, 05:05 pm »
At Nad's suggestion, I returned the amp and exchanged it for another...New Nad has run for 18 hours straight with no shutdown.  Guess the first unit was a little oversensitive.  Both dealer and Nad believe the amp can power the speakers...and at 11o'clock on the volume, the sound levels are about as loud as I would likely go.  Sound is good, although a touch less bass than my Carver 300wpc produced.  Will keep testing and I will try it once again back in the cabinet with at least 6 inches of airspace on the tp.  As suggested, a little computer fan may be necessary.  Appreciate the suggestions.
John Casler
« Reply #8 on: 22 Apr 2006, 07:34 pm »
If you run into the problem again, I have found Active Thermal Management's products to be helpful, and reasonable.
http://www.activethermal.com/Cool-Shelf.htm
Davidinvic
Thank you John
« Reply #9 on: 22 Apr 2006, 08:04 pm »
A great suggestion!  I will check on their pricing.
