Kavent A-210 Integrated Hybrid Amplifier 4-SALE
0 Members and 1 Guest are viewing this topic. Read 2355 times.
Bill Baker
    • Musica Bella Audio
« on: 19 Apr 2006, 01:48 pm »
Hello, I have a like new Kavent A-210 available. It was sold to a customer about 5 weeks ago. The customer ended up in the hospital for surgery and never even opened the box. In th emean time, he decided to go with a full tube amplifier so I took the Kavent back.
 It has very low hours on it here in my showroom only.
 Asking $550 including shipping.
The preamp section uses a 12AX7 and a 6DJ8 tubes with low distortion by-passable tone control and loudness circuit. The power amplification uses four pairs of J-FET power transistors and is Class-A biased. The use of zero feed-back circuitry guarantees the most linear response at the lowest distortion. High-quality components include motorized ALPS volume control, SOLEN capacitors, 650VA toroidal transformer, 40,000uF capacitance, multi-function metallic remote control, and more...
Output Power.............................100W+100W (8 ohm),
                                                    200W+200W (4 ohm)
Class-A Output...........................10W+10W
Frequency Response.................5Hz - 40KHz (±1dB)
THD.................................... .........< 0.05%
Input Sensitivity.........................240 mV
S/N Ratio.................................. ..97dB
Input Impedance........................47k&#937;
Dimension (WHD)......................17" × 6" × 18"
Weight................................. .......45 lbs
