Chassis dampening???
0 Members and 1 Guest are viewing this topic. Read 1316 times.
chriss
« on: 19 Apr 2006, 02:03 am »
Hi Jim,
In your post about the Classis Cornet you mentioned that they came with chassis' dampening. May enquire what you use and is it nessecary when you use the Lansing Chassis?
I should start my Cornet this weekend.
chris
hagtech
« Reply #1 on: 19 Apr 2006, 07:00 pm »
I add strips of rubber to the inside of the aluminum chassis to eliminate the "ping".  All chassis, no matter what they are (except for the Trumpet) benefit from additional vibration damping.  Same with tubes.
jh :)
