Need help from Hagclock builders.
0 Members and 1 Guest are viewing this topic. Read 2581 times.
robertwstephens
« on: 15 Apr 2006, 03:07 pm »
Hello!  Does anyone have 1 of the 39pF BC1008CT caps leftover from their project they could sell me?  Digikey has them backordered for 6 weeks.  You have to buy a bag of 10, but only need 1 for the project. I will mail cash.  I was also wondering if I could use the Cardas 28 guage chasis wire I have lying around instead of CAT5 cable wire for the hookup wire?  Any tips on how I tap in for power and where the hook-up wires go on a Music Hall CD25 would be greatly appreciated.  I plan on removing and using the crystal inside the player.  I miraculously assembled a working Cornet II  that sounds incredible and am now building a Hagclock.  The learning curve is mighty steep right now!  Thanks for the help in advance!  Peace.  Robert
hagtech
« Reply #1 on: 15 Apr 2006, 08:51 pm »
I'll send you a 39pF.  Pretty sure I have something lying around.  The Cardas wire would be ok if you can twist it into the proper geometry.  That is, about 1.5 to 2 turns per inch.
jh :)
robertwstephens
« Reply #2 on: 15 Apr 2006, 11:49 pm »
I will gladly toss a couple of dollars in the mail and GREATLY appreciate the effort on your end.  Peace.  Robert
12AT7
« Reply #3 on: 16 Apr 2006, 12:52 am »
I would  love to get one of those 39pf caps also Jim.
 :D
robertwstephens
Another quick question on Hagclock
« Reply #4 on: 16 Apr 2006, 01:16 am »
On footnote 2 it says to use a 10pF for 11MHZ only.  If I am using the 16MHZ crystal do I not put anything in C17?  Sorry if the answer is really obvious!  Peace.  Robert
12AT7
« Reply #5 on: 16 Apr 2006, 01:35 am »
No to C17
robertwstephens
« Reply #6 on: 16 Apr 2006, 01:55 am »
Thanks for taking the time to reply. Peace. Robert
hagtech
« Reply #7 on: 16 Apr 2006, 03:20 am »
12AT7, ok you get one too.  I'll have to fix manual, as there are plenty of 39pF caps of other numbers available from DigiKey.  They just keep running out of the ones I specify.
jh :)
robertwstephens
Digikey numbers.
« Reply #8 on: 16 Apr 2006, 03:23 pm »
Hello Jim!  If you give me the Digikey number of one that is stocked, I will gladly order it.  I tried ordering a substitute on my own and got these super tiny ones the size of a pencil point.  A Digikey number for the 100 ohm resistor I need for the hookup wire would be greatly appreciated also.  Have a great Easter.  I am in no rush to get a response.  Peace.  Robert
hagtech
« Reply #9 on: 17 Apr 2006, 02:17 am »
Seems at the momnet they have four numbers in stock:
399-4238
490-3652
490-3731
495-1007-1*
Last one min qty 10.  I'd get the first one.
100QBK
jh
robertwstephens
Thanks! 1 more question for now.
« Reply #10 on: 17 Apr 2006, 03:28 am »
Thanks for taking the time to look that up Jim!  I thought I better ask one more question before placing my order from Digikey.  The picture of the Hagclock shows a round red part in the holes marked CLK, GND and in-between C16 & C11.  Are those parts I need to order? If so, a Digikey part number would really help alot.  What are they for?  Peace.  Robert
hagtech
« Reply #11 on: 17 Apr 2006, 04:06 am »
Those are just test points.  Make it easier to attach a scope probe.  Was using #5000K-ND.
jh :)
robertwstephens
« Reply #12 on: 17 Apr 2006, 12:37 pm »
Thanks!  I really appreciate the guidance.  Peace.  Robert
robertwstephens
Thanks for the caps!
« Reply #13 on: 21 Apr 2006, 03:32 am »
Thanks for the caps!  I will drop a few bucks in the mail.  I really appreciate the top notch support.  I hope to spend some more money with you in the future.  Peace.  Robert
