RM/X..help
0 Members and 1 Guest are viewing this topic. Read 1530 times.
ARAM
RM/X..help
« on: 14 Apr 2006, 04:24 am »
I   need  help  about  setting  up  my  RM/x  ..how  is  it  done  properly??
John Casler
Re: RM/X..help
« Reply #1 on: 14 Apr 2006, 02:23 pm »
Quote from: ARAM
Hi Aram,
Glad to see your getting set up.  Likely the best place to start is here:
http://www.audiocircle.com/index.php?topic=18067.msg158156#158156
with the set up tips.
flintstone
flintstone
« Reply #2 on: 14 Apr 2006, 06:01 pm »
I think the CARDAS setup method works well most of the time.
http://www.cardas.com/content.php?area=insights&content_id=26&pagestring=Room+Setup
Dave
ARAM
RM/X..help
« Reply #3 on: 16 Apr 2006, 01:31 pm »
Thank  you  fro  the  replies..I  used  to  have  Paradigm  Studio  100  before  ..Now  these  RM/X;s..so  I  wonder  how  big  the  difference  will  be..we  will  see..
warnerwh
RM/X..help
« Reply #4 on: 16 Apr 2006, 10:08 pm »
Aram: There's no one set method. You have to remember every room is different. Your listening position will also have a large influence.  One thing to keep in mind is don't let the sidewalls be at the same distance as the rear wall or a multiple of it.
Room treatments can also make a huge difference and are a necessity. You don't mention them but if you have some what are they?
At minimum all first reflection points should be treated and at least two bass traps are necessary. More treatment helps alot, it's similar to buying better speakers.
What I've said goes for all speakers. Once you get that done then you can adjust the RM/x's to your liking further.
