Cheap DAC
0 Members and 1 Guest are viewing this topic. Read 2273 times.
CJ Paul
Cheap DAC
« on: 12 Apr 2006, 09:51 pm »
Are there any cheap DACs that I should consider along the lines of the LiteAudio DAC AH?  I'm interested in a tube DAC, NOS DAC or both but will consider other options based on persuasive argument ;)
Nick B
Cheap DAC
« Reply #1 on: 13 Apr 2006, 05:35 am »
This might be more than you want to spend, but you may want to check it out. The MHdt Paradesea is tube and goes for about $450 or so on eBay. Here's a link to a review by Scott Faller.
http://www.enjoythemusic.com/magazine/equipment/0406/mhdt_laboratory_dac.htm
rhart
Cheap DAC
« Reply #2 on: 13 Apr 2006, 01:04 pm »
I have a modified ART DI/O (with Stancor PS and belden DIY digital cable) for sale ($200):
http://www.audiocircle.com/index.php?topic=27126).
Lots of enthusiastic reviews here on audiocircle and on audio asylum. It's every bit as good as the CI audio, Benchmark, Perpetual Tech DACs and, IMHO, almost as good as the ACK DAC.
CJ Paul
Cheap DAC
« Reply #3 on: 13 Apr 2006, 01:16 pm »
Thanks for the recommendations.  I was kind of looking for retail recommendations because I'm not ready to buy yet.  Maybe I'll start a thread or resurrect this one when I am.  I know used provides a greater bang for the buck.
Folsom
Cheap DAC
« Reply #4 on: 13 Apr 2006, 02:19 pm »
I would build Peter Daniels, ok I plan to build one for myself... That or there are a few other nice design on the DIY forum floating around.
When they are finished for a few hundred invested you get the equivlant of a $900-1200 DAC.
jonwb
Cheap DAC
« Reply #5 on: 13 Apr 2006, 02:47 pm »
Quote from: Destroyer of Smiles.
You got a link for that DoS?
BrassEar
Cheap DAC
« Reply #6 on: 13 Apr 2006, 04:00 pm »
gary
Cheap DAC
« Reply #7 on: 13 Apr 2006, 05:27 pm »
Quote from: jonwb
In the "Latest News" section at audiosector.com there's a link to a thread at diyaudio.com with information on how to buy. If I were looking for a low-cost dac this would be high on my list and so would a battery-powered MonicaII kit.
Gary
budyog
  • I don't listen to audio, I listen to music.
Cheap DAC
« Reply #8 on: 13 Apr 2006, 09:10 pm »
I have a 2 year old AVA Omegastar Topp-DAC "For Sale" for $500. It is in perfect condition and I am the original owner.
http://www.avahifi.com/root/equipment/dac/omegastar_dac.htm
mark@marktwain
Cheap DAC
« Reply #9 on: 13 Apr 2006, 09:34 pm »
I would second the Peter Daniels DAC. I'm ordering one now myself.
Also the MHdt Paradesea I heard it at Scott Fallers and it sounds very nice. The Monica from diyparadise also gets rave revews.
Mark
GHM
Cheap DAC
« Reply #10 on: 13 Apr 2006, 10:01 pm »
I'll third the Audio Sector DAC. It is unlike any other DAC or CD player I've heard. If using a preamp or passive volume control keep the input impedance above 50K ohms..100k ohms would be better. This DAC uses Passive I/V conversion. It doesn't use op amps. So it is sensitive to the input impedance it feeds, the plus is a very natural sound without that op amp digititas some analog outputs give you.
