0 Members and 1 Guest are viewing this topic. Read 9836 times.
Maybe I should have asked how can one type of biamping sound better than the other as far as sound quality is concerned. I would like a detailed reason for this.
... What I don't understand is why so many people say it's not worth biamping unless you go active. ...
... Maybe I should have asked how can one type of biamping sound better than the other as far as sound quality is concerned. I would like a detailed reason for this. Thanks. ...
... there are many of us who try hard to minimize the number of components between the source and speakers as every one, we believe, including interconnects has the potential to further color the sound. ...
... still haven't seen anybody show me measurements at the speaker drivers that would account for an improvement in sound with an active crossover over a passive crossover all else being equal. ...
... Does this mean that there's resistance of some sort in these passive devices not allowing the amplifier to operate at it's capability? If this is the case I'd think this should be able to be measured at the speaker driver and if not, why? ...
... I already do have a Behringer DEQ2496 with all the extra cables required (and all of those bad ICs,etc.) in the system and it did not do any damage. Quite the contrary, it did a lot of good and was very transparent ...
