0 Members and 1 Guest are viewing this topic. Read 9833 times.
... Heck, my view of "passive bi-amping" is that it's not even really bi-amping. The traditional concept (which dates back many many years) of bi-amping was always a direct connection between speaker and amplifer and the crossover shifted to line-level. The definition has been skewed in recent years by "audiophiles" who have no understanding of the technical concepts involved. For them, if they have TWO amplifiers they're bi-amping. ...
... Heck, the definition of "audiophile" has been completely bastardized in the past few decades.....but that's another topic...
... A few minor points -Active multi-amping doen't necessarily obviate the need for all passive components betwixt and between the amp and drivers. Often the rising impedance of a driver would still mandate the a Zoebel, or other components, for compensation. ...
To muddy the waters even further, when you go for active bi-amping, now you are introducing an electronic crossover into the system...
Andy,Passive components in shunt positions are still in the signal path, even if only to the extent that their effect is subtractive. One can (although I doubt that I could) make an orthogonal transform from many parallel to series crossovers of arbitrary complexity, for example. ...
To muddy the waters even further, when you go for active bi-amping, now you are introducing an electronic crossover into the system. Does your electronic crossover provide for the same pole points and slopes that the speaker designer wanted for the drivers used? Are you sure of what specifications are really needed? Can you really set all the controls on your electronic crossover to get these specifications. Remember what it is doing is not what the knob is pointed at, that is only an approximation. You need a dual trace scope and signal generator to get the slopes set just right and get the gain equal for both channels. Do you have that equipment available? Does your electronic crossover provide for whatever frequency response "tweeks" that your speaker designer built into the design to make up for speaker characteristics that he knew about but maybe you didn't? What about the active circuits in your electronic crossover? It is really another preamplifier in series with your system you know. You love tube sound but have an all IC electronic crossover? Huh? Lots of ICs likely, lots of inexpensive ICs that you would never tolerate in your main audio preamp I suspect. But now you have them. My suggestion for the best way to eliminate all these variables is to use a great loudspeaker system that can be driven full range with a great amplifier and use a great full range amplifier. ...
QuoteTo muddy the waters even further, when you go for active bi-amping, now you are introducing an electronic crossover into the system... These considerations have prevented me from going that route. Not to mention the fact that additional interconnects would have to be introduced into the chain.
I make a few factual observations, and get answers with a lot of opinions.That's normal around here. Oh well.........How do you select good sounding ICs? Do you know their peak current capacity as compared with the amount of current required to drive the capacitive load of the filters designed around them? Our observations are that no linear op-amp by itself can manage that kind of load. Ever consider the thermal intermodulation distortion caused by the heat transfer from the current amplifer part of the IC die back to the voltage amplifier portion? Most don't even know this problem exists. ...
Theoretically how much difference is there between using an active crossover and a passive crossover? I'd like to know measured differences so we could have some idea of what may be audible.
I presume you have an integrated amp then? (So you can avoid using an IC!)
QuoteTo muddy the waters even further, when you go for active bi-amping, now you are introducing an electronic crossover into the system...Huh? Lots of ICs likely, lots of inexpensive ICs that you would never tolerate in your main audio preamp I suspect. But now you have them. .....These considerations have prevented me from going that route. Not to mention the fact that additional interconnects would have to be introduced into the chain.
