Changing power from US standard to CE standard ?
0 Members and 1 Guest are viewing this topic. Read 1746 times.
LarHed
« on: 10 Apr 2006, 08:17 pm »
Hi again,
I'm looking for a used Brystonamp, and knowing that there is more 2nd hand amps in US/Canada than in Europe (where I live), I wonder how hard it is to change from US standard to Europe standard, 110v/60Hz to 230v/50Hz ? Will it affect warrant ? Any ideas and thoughts are welcome :-)
LarHed
« Reply #1 on: 14 Apr 2006, 08:26 pm »
No one ?
95bcwh
« Reply #2 on: 14 Apr 2006, 09:03 pm »
Quote from: LarHed
No one ?
Some time ago I called up Bryston in Canada, the rep told me that as long as the modification is done by Bryston authorized dealer/service center, then your warranty should be ok.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #3 on: 15 Apr 2006, 03:13 pm »
Hi,
The distributor in the country that the amplifier is going to would be in charge of changing over the electrical requirements ( they know the codes and safety issues).  They would also re-register the warranty in the new voltage with Bryston.
If no distributor then one of our other European distributors would be qualified to do it.
james
LarHed
« Reply #4 on: 16 Apr 2006, 05:03 pm »
Okay, the Conclusion is: Don't import a Bryston unit with different voltage, since you may end up with a not qulified warrent since there is no rep in my country....
