NAD C372 with RM40s in a medium size room
0 Members and 1 Guest are viewing this topic. Read 1786 times.
john1970
« on: 6 Apr 2006, 10:53 pm »
To all,
Just to let all potential VMPS buyers know that if you are placing your VMPS speakers in a small to medium size room a good inexpensive integrated amp to consider is the NAD C372.  My room dimensions are 12 x 25 x8 and the NAD has no problems filling to room with music and does an excellent job on the bass.  My listening position is ~ 9' from the VMPS RM40s and with the correct music I can feel the couch vibrate along with the nearby wall.  I also briefly heard a pair of NuForce 9.02 and I could not hear a difference in my small/medium size room in a nearfield position.  In a larger room with a more farfield listening position a larger amp may be necessary.
Just my experience to date.
John :D
Charles Calkins
« Reply #1 on: 6 Apr 2006, 11:10 pm »
john1970:
 I had a pair of NAD 218THX amps running in mono for six years. Nothing and I mean nothing could get down into that deep bass as the Nad's could. Lot's of bang for the bucks in Nad gear. You would have to spend a lot more $$$$ to top your C372. Enjoy!
                       Cheers
                     Charlie
pacifico
« Reply #2 on: 6 Apr 2006, 11:18 pm »
I've had mixed experiences with the very same amp.  I use it with a set a paradigms. It is very powerful, however I think tht the preamp could be much better. It is a relatively cheap amp for around $800or so. I will probrably mod it out with a tubed preamp to remove some of the harshness I hear.
Charles Calkins
« Reply #3 on: 6 Apr 2006, 11:48 pm »
pacifico:
 Way to go my man! A tube preamp does something for the system. I have the CIAudio D-200 amps and the AVA T7ECR tube preamp. I am very pleased with what I hear now.
 I had a great C.J.-PFR S.S. preamp and when I switched to the AVA it was a much better sound I was hearing. Even with the Nad's
                           Cheers
                             Charlie
pacifico
« Reply #4 on: 7 Apr 2006, 12:07 am »
That's really great... I was considering the dodd audio entry level pre amp for its price. I think you can get one for about 500 w/ 2 preouts. Eventually, I will switch to an almarro set amp or the D200s. They have also caught my eye. As far as speakers go, I guess you can figure that my interest in set amps will go hand in hand with some single driver speakers. I' ll add a sub for full range sound.
Thanks for mentioning your experience with a tube preamp for the NAD. I was really on the fence about it. I need to plot my audio budget very carefully for the next two to three years. I have about $1500 to dump now on purchases.  I  plan roll as much of it into next year as possible so I can get new speakers.
Finally the new odyssey audio preamp has caught my eye but I would like to hear some first impressions. Overall I am not in a rush to buy anyhting for now. the bug that was supposed to bite me in  the spring will probrably bite in the fall.
Charles Calkins
« Reply #5 on: 7 Apr 2006, 12:23 am »
pacifico:
  If you stick with the Paradigms and Nad amp you will not need a sub. My Nad's drove paradigms Studio 100's Great combo. However if you do feel that you need a sub I strongly recommend you consider an M&K Sub. That's all they do is subs and satellites. Great combination. Especially the older versions made in the late 70's or early 80's
                         Cheers
                         Charlie
pacifico
« Reply #6 on: 7 Apr 2006, 01:23 am »
Thanks for the sub recommendation. I'll only get a sub if I go single driver/SET amp. That's at least two years off. As thing stand, I get plenty of bass from system as is. I have my speakers (paradigm monitors) about 3 to 4 feet out from the rear wall. That is where they need to be. They are very postion sensitive. Right now, I think that smoothing things out with a tube pre amp would be the way to go. Our conversation tonight has confirmed that for me. Thanks-ap
Charles Calkins
« Reply #7 on: 7 Apr 2006, 01:36 am »
pacifico:
 One more thing you should try to get that harsh sound out of your system is interconnect cables.
 Take a look at bluejeanscable.com. Very fine products.
                         Cheers
                        Charlie
john1970
Second Recommendations for Blue Jeans Cable
« Reply #8 on: 7 Apr 2006, 01:40 am »
To all,
I also recommend blue jeans cable.  An excellent product at a fair price.  Their standard interconnects use Belden shielded cable with the best RCA connectors I have ever seen at their price.  Period.
John
