Maybe "perfect" stand/pedestal for 626R
0 Members and 1 Guest are viewing this topic. Read 1481 times.
John Casler
« on: 4 Apr 2006, 12:38 am »
Just came across what might offer the perfect speaker stand/pedestal for the 626R. No Beard needed!! :o
It is actually a Speaker Cabinet made by parts express, and comes in what is described as Piano Gloss Black. cherry and Birch.
Cabinet Finish:  Piano Black Gloss
External Dimensions:  22" H x 9" W x 13.5" D
This cabinet comes with a solid front baffle and grill, and that can be removed and the cabinet filled with sand, for a very inert stand.
A little "blue tac" on top and this would give you a very close fit.
If you find that like the speaker a bit taller, just purchase some of the "xtra" baffles to raise them, by placing them under the cabinet.
They run about $100 each, but I don't know what commerically available stand would offer the stability, and fit, for less than $400.
You could put the grills on and have grills from top to bottom, or you could plug the binding post holes (sure you can find a way) and have the shiny Piano Black or wood veneer facing forward.
Take a look.
Or for info look here:
http://www.partsexpress.com/pe/showdetl.cfm&DID=7&Partnumber=302-750
I am a "Parts Express" dealer if anyone has any questions, or you can call them direct.
ted_b
« Reply #1 on: 4 Apr 2006, 01:11 am »
Great find oh wise one.  8)
Campindog
« Reply #2 on: 5 Apr 2006, 01:12 am »
Or you could lay them face down and set your RM30's on them  :lol:
John, didn't you do this with some other speakers? Personally I have some old Mission speakers under mine w/amazing results!!! It did great things to the midrange.
John Casler
« Reply #3 on: 5 Apr 2006, 02:07 am »
Quote from: Campindog
That is part of the "origin" of this idea.
I was looking for three things:
1) A bearded Stand or pedestal for the 626Rs
2) An Elevator for the RM30
3) A wooden case to put the SubWoofer amp into for those who wanted the bass amp, but didn't want to "carve up" their subs, RM40s or RM2s.
I found the PE speaker cabinets, which in its various sizes, "can" be used for each of those functions.
I am a Parts Express Dealer if anyone needs such, or has questions.
And Derek, I'm glad you found the RM30 tweak useful.  I guess now we need to get Frank to get some of these for his 30's :lol:
