0 Members and 1 Guest are viewing this topic. Read 4755 times.
I haven't heard any of the following but I have just settled on an integrated tube amp (well, a hybrid Unico to be exact) after doing a lot of research and from the information I gathered the following are amps you should look at. Onix SP3 (a lot of these on Audiogon for $550+), Jolida integrated, Almarro integrated if you have sensitive speakers.
I don't know about Joilida but on a Sophia EL34 amp, which is an entry level integrated push pull (~500 used), I get the best sound when I turn it all the way up and use another pre amp or SB2 to control volume. I think at entry level, the volume pots on an integrated are not good. If you are not using another source you may consider getting a tube power amp and use the volume control on your Squeeze Box. There are more choices for power amps than integrated amps.
Quote from: chadh That pre-amp will probably be my first piece of tubed equipment.ChadWhat are you going to do for an amp?Raja
Chad,Thanks for the link. Space Tech Lab would be a very long day trip or a short overnighter from my home. Their prices seem reasonable and it is the type of small cottage industry that I like to deal with. So many options: Amp, Preamp, Hybrid, Integrated...etc.
Quote from: rajacatChad,Thanks for the link. Space Tech Lab would be a very long day trip or a short overnighter from my home. Their prices seem reasonable and it is the type of small cottage industry that I like to deal with. So many options: Amp, Preamp, Hybrid, Integrated...etc.I think you mentioned somewhere that you ordered a Space Tech preamp. Have you received it yet and how do you like it?
