Bi-amping with GK-1EL?
0 Members and 1 Guest are viewing this topic. Read 1232 times.
gjfim
« on: 28 Mar 2006, 03:07 am »
Hi all,
I am considering using my GK-1EL in a bi-amp system with an AKSA 100N
and stereo subamps.  I understand I can insert a simple male to two
female RCA adapter into the outputs of the GK-1EL to provide two parallel
outputs (one for each amp).  Will the combined loads from the two different
amps present a problem for the GK-1EL?  I searched the forum, but I
could not find an answer.  Sorry if the topic has been previously
discussed.  Thanks for your help.
Gary
AKSA
    • http://www.aksaonline.com
« Reply #1 on: 28 Mar 2006, 07:11 am »
No problem at all, Gary.
Two AKSA power amps will present a load around 20K, which is fine for the GK1.
Hugh
gjfim
« Reply #2 on: 29 Mar 2006, 02:52 am »
Hugh,
Thanks for your help and quick response.
Gary
