0 Members and 1 Guest are viewing this topic. Read 4726 times.
To all,I am amazed that the relatively small NAD C372 can easily drive my VMPS RM40s to 95+ dB peaks @ 9 ft. listening distance. The bass is excellent and with deep bass recordings the couch I sit on starts to shake! Overall a very musical speaker. Symphonies sound live, vocals sound like the singer is in the room providing a live concert. IMO the finish could be better, but it is on par with the finish on the Linn Indexes / Cambridge Soundworks speakers I have owned in the past. B ...
You'll have plenty of time to do the "PPP" thing as John suggests, enjoy the music and don't be in too much of a hurry to change things, the more you listen, the more you'll know what adjustments are doing the job for you....
To all,My RM40s now sound excellent. Brian sent and new woofer by 3-day air and it arrived in two! Needless to say the new woofer solved the problem and the bass from both speakers sounds identical (or so close I can't tell the difference). I will write a complete review of the speakers once I have more hours on them.Cheers,John
