AV1RS tweeter to the front or to the back of the room?
0 Members and 1 Guest are viewing this topic. Read 1781 times.
Darren Thomas
I'm nearly finished with my AV1RS speakers and can't seem to find anything stating whether the tweeter should be forward or to the back of the room...
Darren
mono-tubeleosis
« Reply #1 on: 27 Mar 2006, 06:17 pm »
Are you mounting them on side walls behind you?  I have mine on the back walls with the tweeters inward pointing toward the center.  I just assumed that was how they were supposed to be.
Darren Thomas
« Reply #2 on: 27 Mar 2006, 06:17 pm »
Ah, forgot to mention that. They will be mounted on the side walls.
RAW
« Reply #3 on: 27 Mar 2006, 08:57 pm »
Darren
When we did ours, I did them both to the back of the room when you are looking at the front of the room.
This all would depend on you seating location.
IF you are seating ahead of the AV1RS then put them to the front of the cabinet.This will bring the tweeter closer to you.
Just my 2 cents.
Darren Thomas
« Reply #4 on: 27 Mar 2006, 09:11 pm »
Ok, yeah, they will be slightly behind me so I suppose tweeter towards the front.
RAW
« Reply #5 on: 27 Mar 2006, 09:33 pm »
Yes that would be my placement.
