Trouble with Bugle + PS
0 Members and 1 Guest are viewing this topic. Read 1716 times.
dhollister
« on: 27 Mar 2006, 03:28 pm »
Hi folks,
I finally got around to building the bugle power supply I ordered a couple months ago.  It seems I built everything correctly.  It puts out about 14.8V.  Then I connected it to the Bugle and no sound.
First, I noticed that I managed to wire the +/-15V backwards when going to B1/B2 on the bugle.  Ugh.  So I reversed them.  Still no sound (and a second blown fuse).  Double-ugh.  I then noticed that I had wired it backwards -- the -15V went to the "+" side and the ground went to the "-" side on the battery connector.  I hadn't even had that much to drink!  I guess that's what I get for trying to follow how to wire the thing based on a picture somebody posted somewhere.
Anyway, I then reversed that connection.  Now the fuses don't blow anymore, the LED stays lit, and I seem to be getting voltage on the bugle, but still no sound.
Any thoughts on what might be going on?  Is it possible I blew something?  I seem to see voltage on each of the op-amps and even on the outputs.  I'm not sure if that's normal or not.  I suppose I'm just out of my league.
Thanks for any help!
David
hagtech
« Reply #1 on: 27 Mar 2006, 07:23 pm »
What voltages are you reading on the opamp supply pins?  What voltage at output?  Are opamps in backwards? :beer:
jh
dhollister
Opamps/voltage
« Reply #2 on: 27 Mar 2006, 07:53 pm »
Quote from: hagtech
jh
Hi Jim,
Thanks for the response.  The bugle was working fine with battery sources before this, and I haven't changed anything there, so I'm sure the opamps are fine.  I'm not sure which pin I was reading on the opamps, but it was the same pin on all three and I was reading somewhere around 13.5 V.  If it matters, I can go back tonight and check the voltages on the right pin (if I didn't hit the right one -- I just picked one at random).
The voltage I was reading on the outputs was also in the neighborhood of 13.5V I think (I'm going by memory and am at work at the moment).
David
dhollister
An update...
« Reply #3 on: 28 Mar 2006, 12:06 am »
I haven't found out the problem yet, but I am definitely seeing 13-14V on every pin on every opamp.  I checked my other bugle which is still a battery powered one and it looks more normal (only voltage on two pins).
I then looked at the switch I had removed to convert the battery powered bugle to use the power supply.  Those connection points are rather small and after installing a switch, removing it and installing two short pieces of wire to act as the jumpers, I may have created some sort of connection between a couple of the points.  I see infinite resistance between the two pins on the upper row, but there is definitely a non-infinite resistance between the two lower points.  There is a bit of flux there which I will try to remove, but I think the bigger problem is the damage done to the circuit board with the brute force of removing solder with my iron and a desoldering braid.
Would it be possible if there was some sort of leakage at those connection points that would cause what I am seeing (voltage on every pin on every opamp)?
Sorry if I'm being somewhat vague.  I can discuss software acronyms and technology with the best of them, but circuitry just isn't my strong suit.
Thanks again,
David
hagtech
« Reply #4 on: 28 Mar 2006, 02:36 am »
Take the opamps out first.  Then debug the supplies.  Seems you might be missing the neg supply, or maybe have driven it positive.
jh :?
dhollister
More info
« Reply #5 on: 28 Mar 2006, 02:57 pm »
Quote from: hagtech
jh :?
Hi Jim,
Here is what I found out last night.  I believe the supplies are wired correctly.  I seem to get -14.9/+14.9 V across the jumpers that I put in.  The problem may be that one of the switch connectors has lost the metal ring around the outside which makes it impossible to form a solder joint there.  I'm wondering if that's why I'm losing my negative voltage (it's the other side of the jumper position from where the -15V comes in).  If that is the problem, I have no idea how to fix it, or if it is even fixable.  After messing with it long enough I finally did get a wire soldered across it, but I fear it's just not making a connection with the trace that leads up into the guts of the board.
David
dhollister
It's alive!
« Reply #6 on: 28 Mar 2006, 04:34 pm »
I decided to give it one last try this morning.  I tried to gently add a bit more solder between the switch pin and the trace.  Like I said earlier, the metal ring that connects to the trace had been removed after so many times messing with the bugle (putting a switch on, taking it off, wiring it to an external switch, then undoing it to connect the power supply).
Anyway, after doing that, I finally saw 0 resistance from that pin to the pin on the other end (where an opamp would go).  I plugged the opamps back in and did some voltage readings.  It looked more normal, so I plugged it in to my system and voila!  Music, sweet and powerful (gotta love Dire Straits' Love Over Gold).
I guess my next step is to get this frankenstein into a chassis of some sort.
Jim, my next beer will be a toast to you  :D
David
