0 Members and 1 Guest are viewing this topic. Read 6982 times.
Can Bookshelf + sub match the sound of a floor standing?
To all,I also have the same issues. I used to listen to a pair of Linn Index speakers with dual REL subs, but I also found that proper integration between the Linn and REL was never ideal. I have sold both REL subs (one which was no longer working) and have since moved to a large floorstanding speaker with three 10" drivers (2 are acitve, 1 is passive) per a channel for more bass reinforcement. As I side note, I grew up listening to a pair of Bozak Concert Grands (with 4 12" woofers / channel). ...
Hate to burst your bubble, but the dual REL subs will outperform your speaker with three 10" drivers. To get really satisfying bass with your speakers you will need to augment with subs. I am not trying to start a war, just giving my observations over the time I owned two pairs of RM 40's. George
My all-time favorite speaker has been the Dynaudio Special 25, a stand mount monitor, larger than a bookshelf - 9w x 16h x 14 deep. It had an 8" woofer that allowed it to go down to 35hz -3db, and could play plenty loud without congesting for my tastes. What made it special was the extraordinary smoothness, clarity, and extension of that Esotar tweeter. It may not have had full scale realism, but listening in the very nearfield in my small room, it gave me more pleasure than any other speaker I've owned ...
A well designed 2 way monitor by its nature has advantages over a large full-range in the areas of coherency, transparency, and precise imaging, which may be due to things like a simpler crossover, close proximity of drivers to each other, and a smaller reflective surface area. What do you think Bill?
Utilizing active crossover in your system can be asbolutely fabulous. It can take your system into the realm of multi, multi thousand dollar speakers and them some.
I am surprised no one has mentioned it since Bill also sells them but the SP Timepiece puts to end the idea deep accurate bass requires a big speaker.ThanksBill
