Need help for SET amp
0 Members and 1 Guest are viewing this topic. Read 1211 times.
tanchiro58
« on: 24 Mar 2006, 08:19 pm »
Hi everyone,
I accidently insert the wrong pins to wrong holes of the 2A3 tube sockets. I did hear the buzzy noise out of the speaker and smoke came out from the socket. My questions are I have replaced new resistors under the sockets but when I turn on the amp the sound is normal but the tubes is getting hotter(from the damaged side) then the other tube. Is anything that I have to replace further in the signal path? Or maybe the tube is damaged? Thanks,
Tan :oops:
SET Man
« Reply #1 on: 24 Mar 2006, 09:03 pm »
Hi,
   I think you damaged the tube. Are you inserting the damaged tube back into the socket after replacing the resistor? :o
   You might want to get a good tube and try it in the side of the amp that you inserted the worng pin and see if the amp and the good tube operate normally.
    I would guess that the tube that you inserted wrong is as good as a goner. If the amp work fine after replacing some resistors as you said than consider yourself lucky.
   By the way what amp and tube you are using anyway? :D
Take care,
Buddy :thumb:
tanchiro58
« Reply #2 on: 24 Mar 2006, 09:45 pm »
Hello,
I am using Sun Audio SV-2A3 with the RCA single-plated tubes (Ouch! that is waisting). Thanks anyway.
Vtech2000
« Reply #3 on: 25 Mar 2006, 03:31 am »
I concur with SET man
