0 Members and 1 Guest are viewing this topic. Read 3784 times.
I have a dual boot win xp and gentoo system, using windows pretty much only for the occasional game. So, here are my observations of running slimserver under both systems.When i've run slimserver from windows, it's buggy as hell. Songs freeze randomly, SB loses connection, ... --pretty much every bug i've seen mentioned in the forums. I've seen these bugs nearly everytime i've run slimserver in windows.I've never had a problem running slimserver under linux --no hiccups, freezes, lost connections. S ...
If you deceid to go the Linux route. I would try either SUSE of OBUTO as they both have very easy installs and are the best at ease of installation and the configuring your system's (sound card ect) devices.
So I tried Suse Linux over the weekend, but it would not install on my machine, or give me enough information to figure out why it was having problems.I know YMMV, but if this was one of the better Linux packages, WinXP or 2000 is looking more appealing.Randy
Randy,I wouldn't have expected there to be any problems installing linux on your box unless you have esoteric hardware of some sort. Where did the installation hang?Linux does take some comittment to get ...
I am trying to resurrect an old PC, and use it to run slimserver, as my music server. It is a Celeron 450, I think it had 256MB of ram, and I stuck an 8 gig HD for the root drive. I will stick in a 250G drive for music.
I am trying to resurrect an old PC, and use it to run slimserver, as my music server. It is a Celeron 450, I think it had 256MB of ram, and I stuck an 8 gig HD for the root drive. I will stick in a 250G drive for music.So, I was going to run win98 on it, until I figured out slimserver won't run on win98. My question is, what operating system to run on it. I was thinking about trying Linux; Fedora Core 5 or Xandros (I can get it free after rebate). Or, I stick with MS, and get an OEM copy of Win ...
Hi Randy,If you bought the Olive device, you don't have to worry about using a PC.Regards.
