Hugh,
Sorry for the long delay. I was promised to attend the local movies this evening, 6pm show, so had to leave just as I posted.
I've now returned, much calmer I might add.
I can duly say that I panicked too soon!! The hum was a true mystery. I must have had the plug on the little player not fully seated, as the hum was a real ground hum, loud too. This has happened before, but I must have been calmer and saw the trouble right away.
However when I did all the measurements everything was fine except for the highish offset at 33-35mv. All other voltage readings were as they should be.
Now, I've plugged things back up and the GK-1 is fine. I made sure the plug on the little player was fully seated, and all played fine.
As I recall last Thursday one of the channels did have a highish offset, though I don't believe it was 35mv. Is that offset reading liveable? OR should we try to find a way to lower it?
Now I'm just pleased that it all works.
Of course the cd player has to go back to the shop with a low output in one of the channels. But the other 4 channels are all fine so didn't wipe anything out, as I'd feared.
I'll sleep good.
