Tube dampers
0 Members and 1 Guest are viewing this topic. Read 849 times.
Ispec2
Tube dampers
« on: 23 Mar 2006, 12:54 am »
Which Herbies tube damper to use with the Modwright SWL 9.ose 5687 tubes, advice appreciated. Thanks
ted_b
Re: Tube dampers
« Reply #1 on: 23 Mar 2006, 01:30 am »
Quote from: Ispec2
Hal-O 9X (xtreme temp).  Those tubes run hot.  I own a pair of these dampers for my SWL.
Ispec2
Tube dampers
« Reply #2 on: 23 Mar 2006, 02:05 am »
THANKS!
TheChairGuy
Tube dampers
« Reply #3 on: 23 Mar 2006, 02:44 am »
You can always use a Mortite or Dennis Rope Caulk dime sized hat on 'em the top, too. Just let the tip poke out a bit.
I've used, or use them on hot running 6n1p's, rectifier, regulator and larger output tubes without a hitch.
The Herbies are decent deals at $9.95 a piece....but I think you can get a package of rope caulk for US$5.00 and it'll do thousands of tubes.
I use the Herbies (the 7, maybe it's called?) on my 6n1p's and 12ax7's...in conjunctionwith the mortite top hatter. I want to hear the effect of the tube - not the microphony that often comes along with tube listening.  When you damp those tubes real good, the audible difference between SS and tubes slims up quite a bit closer.
Of course, many enjoy the microphonic/euphoric effects - to each is own in life - my power to it, say I :)
The rope caulk does some off if you don't like their effects...harder to get off than a Herbie's Tube Damper will, tho.  But cheaper - much.
