Well, it ain't pretty, but........(Bugle)
0 Members and 1 Guest are viewing this topic. Read 1365 times.
Sarchi
« on: 22 Mar 2006, 11:16 pm »
It sounds mighty good!!  :D
Got the SLA batteries today, Panasonics from Digikey, $18 each.  The only issue I have now is a faint buzz in one channel, touching C10 kills it so I guess the cap isn't well grounded(?).
Anyway, subjectively the sound is improved a bit from 9V alkalines... but then again I ran those dead so the poor Bugle probably didn't sound its' best the last 1/2 hr or so.
Couple of pics.  I know, I should've just used thin magnet wire... I'm not used to working with DC!  :roll:
(the case is a wood jewel box from the local dollar store)
(you thought YOU had a small room??)
