0 Members and 1 Guest are viewing this topic. Read 3034 times.
How about a floor standing line of four FR125s, ported? Sensitivity would be mid 90s, and the bass fairly impressive.Yes, there will be comb filtering issues, though I doubt the sound will be seriously degraded over a single FR125. A 4.5" driver naturally beams, and won't have a ruler flat response (to 20khz) while producing 60hz tones.Of course, this would cost double.
Quote from: Jason1How about a floor standing line of four FR125s, ported? Sensitivity would be mid 90s, and the bass fairly impressive.Yes, there will be comb filtering issues, though I doubt the sound will be seriously degraded over a single FR125. A 4.5" driver naturally beams, and won't have a ruler flat response (to 20khz) while producing 60hz tones.Of course, this would cost double.Actually that would be three times as much. It does sound fun though... I could just go with the Visaton B200's instead if that was the case, where I had more to invest.
I found this thread over at DIY audio.http://www.diyaudio.com/forums/showthread.php?s=&threadid=75789&perpage=10&pagenumber=1What do you think? -3db at 45hz not bad huh? The PR is definatly closer to a sealed. When I plotted a sealed in WinISD it barely went below 100hz :/ The other thing I was thinking about was this thing instead of a PR for a similiar to sealed box, http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=296-546
