I've finally started burning most of my CDs via Nero on PC
0 Members and 1 Guest are viewing this topic. Read 1888 times.
Rob Babcock
I will admit, I've been pretty slow to get with the 21st century regarding CD-R burning, but I just added a 40 gig HD to my 2 1/2 yr old computer and got Nero Express- now I see what all the fuss is about! :wink:
I love Nero:  the Wave Editor function is awesome, allowing you to edit songs, perform fades, plus a lot of other stuff that I haven't explored yet.  The digital volume matching is also fantastic, and does an amazing job at making your compilations sound like they all came from the same album.
I remember not long ago a thread here where I complained that the burning software was complicated and too cumbersome for me to use;  I can definately say that Nero 5 has changed that.  I've officially done a 180 here!
The only downside-  I just bought Denons top dubbing CD deck about a month ago!  Guess that's gonna gather dust now! :x
CELT
« Reply #1 on: 20 May 2003, 11:00 pm »
Thanks for the head up on Nero. A friend of mine has it and like it as well. My three year old Adaptec software is flaky and I would like something better.  I have a "pro" Marantz stand alone that I also use, but am thinking about selling it. Heck Rob, sell yours too!
« Reply #2 on: 20 May 2003, 11:22 pm »
Get the new Yamaha burner (that has the "audiomaster" mode), Nero, and some black CD's - your ears will thank you :-)
CELT
« Reply #3 on: 21 May 2003, 03:10 am »
I downloaded Nero 5 this evening. I have been using the black TDK's for a little over a year now. They are all I'll use.  :wink:
Rob Babcock
« Reply #4 on: 21 May 2003, 05:12 am »
In my neck of the woods the only black discs I can get are Memorex.  While I haven't had any prob with the several hundred I've used, I know Tyson has had terrrible luck with them.  Suppose I could probably buy em online somewhere.
So, do you guys believe the black ones sound different/better than silver ones?  I haven't had the chance to try it myself yet.
I'm using a TDK VeloCD right now, and I'm pretty happy with it.  I have a KHypermedia unit sitting in the drawer awaiting install; my brother has one and it'll read damaged discs that befuddle my TDK.  Is the Yammy better yet?
On a related note, how much difference have you noticed in discs burned at different speeds?  I burn at 8X, mostly because discs burned at higher speeds won't reliably play in my aging Phillips player.  I suppose it's audio nervosa, but I'm leery of going faster as I've heard the discs don't sound as good.  I'll probably give it a try someday, but I'll probably need to buy a new CD player first.
Since I installed a bigger HD, I mostly leave tracks on my computer now instead of needing to erase them after each disc.
bubba966
« Reply #5 on: 21 May 2003, 05:30 am »
Quote from: Rob Babcock
I don't have as much experience with doing Redbook copies as I do with copying other discs so I don't know how much of my experience applies.
But when I used to burn PSX discs back in the day (many years ago...) I used to have problems with the FMV cut scenes if I burned them any faster than 1x. Playstations are very sensitive to disc type & burn speed. So if it holds true on a PSX, it probably holds true with everything else as well. Maybe just to a different extent.
I personally never much cared for Nero. I like using CDRWin & Adaptec for most everything.
Rob Babcock
« Reply #6 on: 21 May 2003, 05:38 am »
Nero used to be second banana to Roxio, but according to pretty much every PC mag & Tech TV show I've seen, with Nero 5 the roles are reversed.  N5 definately kicks serious ass, and is incredibly easy to use.
Hmmm...haven't tried burning a PS game yet.  I do have a couple I'd like to 'backup'.
CELT
« Reply #7 on: 21 May 2003, 01:35 pm »
Wal-Mart (yecch) carries the TDK black data discs. They defianetly have an edge over the regular discs.  I don't know if it's reflectivity, or a lack of laser scatter.  I just know they make "better" copies. The dark dye is also less prone to deteriorate the burn from UV exposure.  I always burn as SLOW as possible. The slower speed means a deeper burn.  If I do a high speed burn on the computer, you can barely see it. If I slow it down to 2x, then the burn is very noticeable. The Marantz, of course, burns at real time, so it provides the deepest (darkest) burn. I think this makes a huge difference.  The CDP wil thenl have less problems reading it.
