Help me treat this room
0 Members and 1 Guest are viewing this topic. Read 1810 times.
CornellAlum
« on: 18 Mar 2006, 11:53 pm »
Hey guys, I could use some help treating this room.  I live in a condo by myself, so while there is no WAF, I tend to have a number of corporate type guests over on a regular basis as well as other meaningful people, so I would like it to look fairly decent.
Check out these two pictures at the websites below.  I snagged them off a realator's page, but they are the same exact layout as my room.
http://www.lkrinfo.com/lkrlistings/rmres/listings/images/650_6.jpg
[/url]http://www.lkrinfo.com/lkrlistings/rmres/listings/images/415_2.jpghttp://
According to the diagram I snagged from out in front of one of them, the room is approximately 13.3 X 15.
The challenges of the room are the opening on the short wall where I have my rack at the moment, the glass sliding doors, the 45 degree angle by the fireplace, and the opening to the kitchen and the door.
I have addressed some of the problems with a behringer, but would like to do more if I could.  Thanks for any and all help.  Commercial folks feel free to help and make suggestions as well.
Ethan Winer
  • Audio expert
Re: Help me treat this room
« Reply #1 on: 19 Mar 2006, 02:50 pm »
CA,
> I could use some help treating this room. <
This is a deep subject, and a complete answer requires far more than will fit into a single reply here. The short version is:
* Broadband (not tuned) bass traps in as many corners as you can manage, including the wall-ceiling corners.
* Mid/high frequency absorption at the first reflection points on the side walls and ceiling.
* Some additional amount of mid/high absorption on any large areas of bare parallel surfaces, such as opposing walls or the ceiling if the floor is reflective.
For the complete story see my Acoustics FAQ:
www.ethanwiner.com/acoustics.html
You may want to do everything listed above, but that's the goal anyway.
--Ethan
CornellAlum
« Reply #2 on: 19 Mar 2006, 04:43 pm »
Thanks, I will have a read.  My biggest issue I think is that my right speaker's port fires directly into an open recessed space which is a door.  Any ideas?
« Reply #3 on: 19 Mar 2006, 09:28 pm »
Port discharges are over rated IMO.  The free air space immediately beyond the mouth of the port reduces the back pressure to zero, so 6 inches or 6 feet or open air makes no difference.
bpape
    • Sensible Sound Solutions
« Reply #4 on: 20 Mar 2006, 12:01 am »
Be careful with getting too close though.  6" from the port can cause some pretty strong back-waves that will cancel the reinforcement from the port resonance.  General recommendations is at least a foot - not counting SBIR effects.
Glenn K
« Reply #5 on: 21 Mar 2006, 11:35 am »
Quote from: CornellAlum
[/url]http://www.lkrinfo.com ...
You really want to try to get as much bass trapping in your room as possible.. Here is a link to a set up for one room done.. Also helps you understand what is going on in our room acoustics.
http://www.sbrjournal.net/currentissue/articles/acoustics/Acoustics.htm
Glenn
