The Rectifier and voltage Regulator tubes never made it here on Friday.....FEDEX re-routed them God-only-knows-where.But, the Odyssey Khartago Mono's arrived. I set them up Saturday morning. Three notes - game over. Never have I heard more of everything I've been looking for for many years. It's still quite obviously stiff legged (needs weeks to break in according to Klaus), but all those things I suspected were room interaction/poor configuration, lousy midrange for the cheap Peerless woofer ...
THESE AMPS SOUND AS GOOD AS ANY POWER AMPS IVE HAD IN THE PAST AND PRESENT.DYNACOS,HEATHKITS,HARMON KARDON,ETC.IVE BEEN RUNNING THESE AMPS THROUGH MY PRESENT SYSTEM USING DYNAUDIO AND ALTEC DRIVERS,TUBE CD PLAYER AND A LUXMAN PREAMP.BEEN RUNNING THESE FOR A MONTH NOW.I CAN TELL THE DIFFERENCES BETWEEN THE GOOD THE BAD AND THE UGLY.WHILE THESE AMPS ARE'NT THE PRETTIEST,THEY HAVE GREAT TONAL CHARECTERISTICS:SMOOTH,SILKY HIGHS AND A OPEN MIDRANGE.THE TUBE COMPONENTS ARE;1-5U4 RECTIFIER,1-OD3 VOLTAGE REGULATOR,2-12AU7 AND 2-6CD6 OUTPUT TUBES.ALL TUBES AND CAPS HAVE BEEN CHECKED AND REPLACED WHERE NEEDED.ONE OTHER GOOD THING ABOUT THIS AMP IS THAT THE TUBES ARE INEXPENSIVE TO REPLACE WHEN NEEDED.THIS AMP IS RACK MOUNTABLE AND HAS A VOLUME POT MOUNTED ON THE UNDERSIDE OF UNIT.
Ultra bummer. Hopefully it was only the cap and maybe a resistor that let loose. If it was a tranny, thats a different story altogether. Don't forget that if you change a cap or resistor you need to change the matching cap or resistor in the other amp too. Otherwise you could end up with a sound mismatch between the amps. Who knows, maybe you'll get really lucky and find out it was only a weak fuse
