0 Members and 1 Guest are viewing this topic. Read 28020 times.
I would change the rectifier first to see things tighten up and this tube usually adds something to the overall sonic. Then the input/drivers. Those might be the best tubes to keep, because they last forever, run fairly conservative, well below their rating, and the NOS 12AU7 are quite pricey. Do those only when you have replaced the voltage tube, and rectifier.
....did I just cross over from the dark side, Tube-oholics?...
....Any truth to the rumour that your moving to St. Louis ?...
We've got a place for all you lost souls out there. Hey Chairguy, listen and enjoy for a while, then just when you thought it can't get any better, swap out your coupling caps, change the B+ resistor(s) and replace and upgrade your power supply caps. If you think your in heavan now, just wait, cuz you're only in Iowa. Send me a couple of close ups and I'll point out which ones to go after.Oh and BTW, those aren't hideously ulgy, they're beautious
When all is said and done, a tube amp really is only as good as its power supply, and especially its output transformers. The older stuff was really taken care of in this department, and the state of the art was realized in these type of PP designs, YEARS ago, IMO.
Skrivis,I think you are electing to twist my words somewhat, so I reply. I was merely stating that tube art hasn't gone far in years and years. Much of what is stated as "new" has also been forgotten, and they don't make steel like they used to. Very generally speaking, you can EXPECT, okay, that the quality of iron from a company like DuKane, of this vintage to be very good. Let us avoid hair-splitting. Very general statements on my part.
