0 Members and 1 Guest are viewing this topic. Read 10169 times.
I'm not clear if your comparisons involve SB analogue output or digital output (into what DAC)?
"From what I understand from Den, RWA mod is not to the highest level when BPA option is not selected."Thanks for the feedback woodsyi, but I wasn't sure what "BPA" referred to above.
Pretty amazing how quickly one gets spoiled by line conditioning!
I talked to Wayne and we are not sure why his ultimate power supply seemingly works better than battery since he also tried battery. I am sure Vinnie is trying to figure out what the reason for this is also. Of course Vinnie's mod including the BPS cost less then Waynes if you figure in the ultimate power supply, but money can't be the only thing..
The 12V, 10Ah SLA battery that I use can easily output > 10A if it was ever needed at still maintain 12V (of course it would discharge in an hour if supplying a constant 10A, but I'm just stating this to make it clear that it has LARGE output current).
This is simply not true! The Amp Hour rating tells you how much amperage is available when discharged evenly over a 20 hour period. The amp hour rating is cumulative, so in order to know how many constant amps the battery will output for 20 hours, you have to divide the amp hour rating by 20. Example: If a battery has an amp hour rating of 10, dividing by 20 = 0.5. Such a battery can carry a 1/2 amp load for 20 hours before dropping to 10.5 volts. (10.5 volts is the fully discharged level, at which point the battery needs to be recharged.)-Krull
Amp-Hour battery rating: This is a common battery rating of batteries. Amp-hour rating of battery capacity is calculated by multiplying the current (in amperes) by time (in hours) the current is drawn. Amp-hour battery rating is commonly used on sealed lead acid batteries used in UPS systems, emergency lights and camcorders. For example: A battery which delivers 2 amperes for 20 hours would have a 40 amp-hour battery rating (2 * 20= 40).
In any case, my point was that the 10Ah SLA battery that I use can supply LARGE current if needed (you can easily get 10A...test it for yourself with a 1-ohm resistor).
II would highly recommend that people not try this. Shorting out a lead acid battery can cause it to explode. (A 1 ohm resistor is in essence a short circuit).
Thanks for chiming in Vinnie. I know for a fact that my current meter does not go over .8 amp when I play. But could there be a headroom issue on transients for batteries? Since all things have pros and cons, is the con on the battery somehow to do with slew rate? If so, what can be done to improve it?
In terms of sound quality when powering the SB, I have found SLA power to be all pro and no con.
Again, my point is that large currents can be generated with SLA. 'Nuff said
Some people may take your "expert" opinion as gospel and hurt themselves in the process. -Krull
