Clari-T with volume controls
0 Members and 1 Guest are viewing this topic. Read 1656 times.
bebop Len
« on: 17 Mar 2006, 12:43 am »
Can units with a vloume cintrol also be used with a preamp?
bebopLen
gongos
« Reply #1 on: 17 Mar 2006, 12:53 am »
yes
Vinnie R.
    • http://www.vinnierossi.com
Re: Clari-T with volume controls
« Reply #2 on: 17 Mar 2006, 03:36 am »
Quote from: bebop Len
bebopLen
Hi bebop Len,
Welcome to Audiocircle!
Yes, if the Clari-T has a volume control, you can still use preamp in front of it.  You would need to max out the Clari-T volume and use the volume control of the preamp.  If the preamp has too much gain, you can cut back on the Clari-T's volume control.
Even better than a volome potentiometer for this application is a stepped attenuator (I mention DACT parts here, which are top quality:
http://www.redwineaudio.com/Clari_T_Customization.html)
Best regards,
