Advice on cables needed.
0 Members and 1 Guest are viewing this topic. Read 1598 times.
Folsom
« on: 16 Mar 2006, 07:19 pm »
I have been using 9259 Belden Coaxial as of late... I considered 89259 because it is easier to work with, but I have also read about oxidation problems.
I want some thing that sounds as good, because this stuff is nothing short of amazing. If I attach cheap bananna ends on it from radioshack I loose significant quality is sound.....
http://www.diycable.com/main/produc...products_id=445
and
http://www.diycable.com/main/produc...products_id=528
have been two considerations....
What do you guys think of the
http://www.diycable.com/main/produc...products_id=248
for AC power wire?
Any suggestions are welcome. I plan to use Bullet copper plugs, onto Exodus high copper content RCA jacks.
Parts connextion has...
D.H. Labs BL-1 Silver Sonic 20 awg balanced interconnect cable
and also D.H. labs ST-100 Silver Hybrid Speaker Cable, OFC + silver plated OFC, 14 awg. speaker wire
Percy has...
Canare Star Quad L4E6S that I looked at as well.
Who sells nice IEC chassis mounts with the fuse holders/switch ? I have been trouble finding any that are not the ordinary $1.95 ones.
rez
« Reply #1 on: 17 Mar 2006, 03:48 am »
I've been doing lots of searches for parts as well - came across these at digikey
http://www.qualtekusa.com/catalog/ac_recept/PDFs/76218002.pdf
The combo switch/iec entry/fuse units look to be priced between 8.49 and 11.26
rez
Terry Rossen
DH Labs is the way to go
« Reply #2 on: 17 Mar 2006, 04:00 am »
Hi,
Back in the day...when the Audiophile Network was the rage, everyone used DH Labs T-14 speaker cable to create high-end AC power cords.  DH labs manufacturers their own PowerPlus AC cord.  You can buy it in bulk form at any length, add your own watts IEU and Hospital plug...nice. Yeah, Parts Conextion should have a bunch of different brands of cables to test out.
Jeff Dorgay at Tone Audio wrote a nice review about the PowerPlus.
http://www.tonepublications.com/
Terry
Folsom
« Reply #3 on: 17 Mar 2006, 03:29 pm »
Thanks guys!
