Speaker Wire for Omega's with tube amp?
0 Members and 1 Guest are viewing this topic. Read 2389 times.
bebop Len
« on: 12 Mar 2006, 05:08 pm »
Any suggestins  for Super 3 XRS wiyh my Scott 222?
It has a large soundstage but is a bit warm with the RFT 12AXS (East Germanlabled Amperex) wiich are the best I could afford.
bebop Len
Brad
« Reply #1 on: 12 Mar 2006, 06:55 pm »
I have used the Mapleshade cables with my Scott 222c and both Omega Super 3's and A8's.  Very happy with the sound.
bebop Len
Thanks Brad
« Reply #2 on: 12 Mar 2006, 11:53 pm »
Thanks, Mapleshade was on my short list so good to know-though some claim they are a bit bass-shy.
Len
Brad
« Reply #3 on: 13 Mar 2006, 12:15 am »
If you're concerned about the bass you could always go with the double version - Mapleshade claims better output down low.
I also like the sound of my Anti-cables in this setup (Paul Spelz' magnet wire), but found the Anti-cables a pain in the @ss to work with (yes, even more than the stiff Mapleshades)
The Greg Straley cables also really interest me, but I have not tried them yet.
maxwalrath
« Reply #4 on: 13 Mar 2006, 12:17 am »
Bolder m-80 had deeper bass than speltz anti-cables in my set-up with super 3r's
Brad
« Reply #5 on: 13 Mar 2006, 12:20 am »
Max - great tip on the Bolder M80's.
Very balanced sound, MUCH more flexible, and in the same $$ ballpark.
Plus Wayne is a great guy to deal with.
