Bulge Pro OPAMP question
0 Members and 1 Guest are viewing this topic. Read 3285 times.
PatOMalley
  • This text is personal
    • http://home.comcast.net/~omaille/audio/home.html
« on: 11 Mar 2006, 01:40 am »
any issues with swapping the following opamps at output?
Burr Brown OPA 2228 or 2227
AD 823 AN (Analogue Devices)
Burr Brown OPA 627 BP on Browndog adaptor
hagtech
« Reply #1 on: 11 Mar 2006, 06:44 am »
Just make sure they are dual devices.
jh
Orson Garnsey
Re: Bulge Pro OPAMP question
« Reply #2 on: 14 Mar 2006, 11:34 pm »
Quote from: PatOMalley
 :D I tried AD825s on Brown Dog dual SO8 to single DIP adapters before settling on AD8620 duals.
Also tried OPA627s 637s 2604.
Have fun. Just don't plug'em in backwards.
PatOMalley
why AD826 duals
« Reply #3 on: 15 Mar 2006, 12:40 am »
so why did you settle on the AD826 duals?
Orson Garnsey
Re: why AD826 duals
« Reply #4 on: 17 Mar 2006, 03:57 am »
To my ears. the AD8620 provides the best of everything; the bass depth, control and resolution trounce the other opamps, they provide mid-range performance on par with the OPA627/637, and have better treble extension than the others as well (air, soundstaging).
The OPA627/637s are good, but a bit "wooly", or perhaps "dark",  in my opinion. They lack the detail of the 8620. The 825s were close to the 8620s, but lacked low-end control and resolution.
One thing to consider is that AD recommends a supply of 13v. I power my Bugle with two 12v SLA batteries and am very satisfied. I don't know how the Bugle would react with 8620s powered by a 15v DC supply. However, I'm sure regulating the supply to 12v is not an issue. Batteries can be had via eBay for $8 each. (Gruber Power).
FYI I modded my DAC as well. It came stock with the OPA2134. In the DAC, I much prefered the AD825s in a Brown Dog adapter. The 8620 was "grainy" in the DAC, while the 825s are buttery-smooth with no loss of detail.
Of course, the 8620s are pricey. I ordered up samples from BurrBrown and AD for my comparisons. Hagtech could not possibly spec the 8620s in the Bugle circuit as the cost would be prohibitive.
CIAudio
    • http://www.ciaudio.com
« Reply #5 on: 17 Mar 2006, 05:34 am »
One thing to consider is that AD recommends a supply of 13v. I power my Bugle with two 12v SLA batteries and am very satisfied. I don't know how the Bugle would react with 826s powered by a 15v DC supply. However, I'm sure regulating the supply to 12v is not an issue.
AD826 is a single op amp specified for +/-15v, maybe you're thinking of the AD8620?
Running them at +/-12 shouldn't be an issue unless the circuit requires it for the needed gain.
kylek
« Reply #6 on: 17 Mar 2006, 05:47 pm »
The AD826 is a dual according to the manufacturer's data sheet.
CIAudio
« Reply #7 on: 17 Mar 2006, 11:20 pm »
Yep, I knew that...my hands don't always type what im trying to say  :|
Orson Garnsey
« Reply #8 on: 18 Mar 2006, 12:47 am »
Quote from: CIAudio
AD826 is a single op amp specified for +/-15v, maybe you're thinking of the AD8620? Running them at +/-12 shouldn't be an issue unless the circuit requires it for the needed gain.
Kudos to Dusty for catching this, because it is I who made the typo... I AM using AD8620s in my Bugle; not sure how I botched that one. Anyway, I like the AD8620 in the Bugle very much. I never tried the AD826!
Previous posts edited.
