Speed up break-in of SB and PS
0 Members and 1 Guest are viewing this topic. Read 1772 times.
Wayne1
« on: 7 Mar 2006, 11:23 pm »
The modded SB and linear power supplies do take some time to break-in.
The capacitors used in the power supply take time to form.
One thing that I have found to help speed up the process is to play a full bandwidth signal at very high amplitude
Jim Hagerman's FryKleaner does just that. It is a great product to use for cable and amplifier break-in.
Jim has a .wav file of the FryKleaner "noise" on his website.
http://www.hagtech.com/media/frykleaner.wav
If you take this "noise" and play it on repeat through your SB (with the amps turned off) it should speed up the break-in time.
DeadFish
« Reply #1 on: 7 Mar 2006, 11:40 pm »
Thanks a lot for the tip, Wayne.
I don't know why, but I just hadn't thought about the break-in period on the new SB3, like I have with other gear.
Guess I'll have to get on that... :wink:
DeadFish
