SP2 bass management ?
0 Members and 1 Guest are viewing this topic. Read 1298 times.
cameraman
« on: 6 Mar 2006, 03:46 am »
On the SP2, if the front left/right speakers are set as large, all others are set to small, and sub is set to none, can the processor send the LFE information to the front L/R speakers?
I currently use the 10B sub crossover with a passive subwoofer and main speakers that are optimized for frequencies from 70 Hz on up so I am looking for the best way to configure them  as I move from a two channel system to a 5.1 channel system.
http://www.northcreekmusic.com/Vision/VisionInfo.htm
Analog by-pass is a priority so if I understand correctly, my front L/R speakers need to support full range.  If I do that I’d rather not add a second subwoofer to enable LFE output.
nicolasb
« Reply #1 on: 6 Mar 2006, 09:54 am »
I'd be surprised if it couldn't - even the SP1.7 is capable of that.
cameraman
« Reply #2 on: 6 Mar 2006, 02:50 pm »
Quote from: nicolasb
I hope it does but I didn't find any reference in either the SP 1.7 or SP2 manual.
  • The Demo is Everything!
    • http://www.bryston.com
Re: SP2 bass management ?
« Reply #3 on: 6 Mar 2006, 08:37 pm »
Quote from: cameraman
Analog by-pass is  ...
YES the .1 will be directed to the Left/Right Large speakers.
james
