Source component burn-in?
0 Members and 1 Guest are viewing this topic. Read 1141 times.
John B
« on: 18 May 2003, 02:42 pm »
I usually don't bother with dedicated burn in of players, but was considering doing so with my new SACD player.   In an email response from the dealer on the subject he told me that I needed to have my amplification on, and at normal listening levels.   Why?  Isn't the player sending out a signal to the pre-amp, which then acts on that signal.  The player will send out a signal regardless of what a pre-amp does with it right?  Or is there some interaction between the two I'm unaware of that would facilitate the break-in of the source component.
starlet
« Reply #1 on: 19 May 2003, 12:37 am »
Whe I first get the norh cd-1, I left it power up for about 10 hours before listening but it doesn't seems to help.
I end up letting it spin a disc non stop without powering up the pre and power. It helps.
